NI Home
Cart Cart | Help
You are here:
Reply
Member
jose_123
Simple 872B VXI read write
Hi all,
I am working with the 872B vxi controller.  I tried using the register write and read but don't get any results.  I don't get errors.  I would like to write to a specific location and read the same location.  I should read what I wrote at the location.  However, all I read is a zero.  Anyone have any insight on what maybe happening?
other info
OS: Windows XP
LabVIEW: 7.1
thanks,
Jose
Member
Jake_H
Re: Simple 872B VXI read write
Hello Jose,
I'd like to get some more information on your application.
  • What modules or devices are you trying to send and receive commands from?
  • How are you sending the commands (VISA, RLP, etc.)?
  • What commands are you sending?
Any other information on your configuration could help diagnose what's going on with your VXI system. Thanks.
Jake H | Applications Engineer | National Instruments
Member
jose_123
[ Edited ]
Jake,
I am sending the commands (VISA) via High level registers.  The modue I am tring to write to is the slot 0 controller.
I am sending commands via "VISA Move out 16" to write and "VISA In 16" to read.
Hope that helps.
Jose
Member
Jake_H
If you're programming in C, you can try this example to see if your results improve. If you are using LabVIEW, I would recommend trying this one. Otherwise, what software interface are you using to send/receive VISA commands (LabVIEW, Measurement & Automation Explorer, etc.) and can you post screenshots of your software configuration?
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
