NI Home
Cart Cart | Help
You are here:
Reply
Member
punamit
NIDAQmx API's for MXI-2
Is it possible to use NIDAQmx API's instead of NI-VISA/NI-VXI API's to control a VXI system
Which standard PCI based cards are available for this purpose from NI with example programs
Member
tyler-c
Re: NIDAQmx API's for MXI-2
The only form factors available for the NI-DAQmx API are listed here:  http://www.ni.com/dataacquisition/.
Tyler C
Member
punamit
Thanks tyler for the reply
I want to use PCI MXI-2 card on my PC. I want some sample program based on VC++ 6.0 to test NI PCI MXI-2 card. please let me know if you have come across this.
Member
tyler-c
The NI PCI-MXI-2 is a MXI link and not a data acquisition device. You can use the NI PCI-MXI-2 with a NI VXI-MXI-2 within a VXI chassis -- then place VXI instruments in the chassis, power on the chassis and boot up the computer, and run RESMAN to find your instruments. Here is a slew of resources for you to familiarize yourself with.
NI VXI-MXI-2 for PCI:  http://sine.ni.com/nips/cds/view/p/lang/en/nid/12833
PCI-MXI-2 User Manual:  http://www.ni.com/pdf/manuals/321032a.pdf
VXI-MXI-2 User Manual:  http://www.ni.com/pdf/manuals/371692a.pdf
VXI Technical Library:  http://zone.ni.com/devzone/cda/tut/p/id/5011
Software for VXIL  http://zone.ni.com/devzone/cda/tut/p/id/4118
The NI PCI-MXI-2 is not an instrument. So if you want to do data acquistion in your PC, you'll need to purchase a PCI DAQ from here:  http://www.ni.com/dataacquisition/. For more help with data acquisiton questions, you should post in the data acquistion forum.
Tyler C
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
