07-19-2011 04:14 PM
I work in a secured area and we recently purchased 2ea of the VXI-PCI8026. Can someone direct me to a Letter of Volatility for the EEPROM on the VXI-MXI-2 and PCI-MXI-2 module/board? Also, what exactly is the size of the EEPROM, I couldn't find this mentioned anywhere in the manual.
- Darin
Solved! Go to Solution.
07-20-2011 01:41 PM
Darin,
Thank you for using the Forums. I believe the document that you are looking for can be found here.
I hope that helps.
Brian P.
07-20-2011 02:08 PM
Hello Brian,
Thank you for the quick reply. Does that Letter of Volatility apply to the VXI-PCI8026 also, even though it states it's for the VXI-PCI8015? If that's the case, I'm assuming it applies to any VXI-PCI80xx and that the only difference between the VXI-PCI8015 and VXI-PCI8026 is the software package that ships with the module and board? Is that correct?
- Darin
07-20-2011 02:30 PM
Darin,
You are correct, I have checked the part numbers for both boards and the actual letters of volatility and they are the same. I am sorry for the confusion. I hope that cleared it up.
Brian P.
07-20-2011 02:32 PM
Excellent! Thank you very much!
- Darin
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
