VXI and VME
I am using VTVMSMIP_32.DLL and the smip_closeRelay() is not working properly.
The VXI chassis is A24 addressing. Some relays work but some relays are not working and when i call VTVMSMIP_CloseRelay() to close relay 1 it closes some other relays .. Can you please let me know whts the problem ? the same works with the SMIP front panel.
(6,347 Views)
I searched through our support resources for the function calls and files you describe in your question, but was unable to find any reference to them. If the hardware and software you are using is from another company, I would recommend checking with them on why your application is not working properly.
Ryan Tamblin
(6,347 Views)
I am experiencing a similiar problem. I am curious what version of the driver from VXI Technology you are using? I am using 3.41 and the relays do not appear to be closing properly. Additionally, I receive an error at line 1176 in vtmsmip.c, which says "Dereference out of bounds pointer: 1 bytes (1 element) past end of array". Have you seen this before?
(6,347 Views)
