Hello Greg,
Unfortunately, the timing of the VXI-MXI-2 cannot be adjusted to support a longer SYSRESET* assertion. I would first suggest that you check with the manufacturer of the Rubidium clock device since it is a VME spec. requirement that any device needing a longer SYSRESET* should actually assert that line directly itself (Permission 5.4 of the VME spec).
Despite that, if it were possible, NI would have gladly provided a method to lengthen the SYSRESET* assertion if reasonably possible. However, after reviewing the hardware design, I have verified that adjusting the timing of the SYSRESET* line is not physically supported on the VXI-MXI-2. Short of redesigning the hardware (we checked thoroughly), the board simply cannot adjust it's own SYSRESET* asertion t
ime.
I recognize that having the flexibility to do this would indeed resolve your situation, and I have filed a request that R&D consider this feature in future designs to accomodate out-of-spec. devices.
Unfortunately, I also recognize that this doesn't resolve your situation now, but again, the device manufacturer would be a better place to start so that they can correct the operation of their board.
Best Regards,
Josh Hernstrom
VXI Product Support Engineer
