Just to answer this old question in case anyone else comes looking for the same thing: no, the 16-bit libraries use a different mechanism for getting information from Resman and the kernel drivers than the 32-bit libraries, so the information needed for the old libraries will not be present when using the new Resman and kernel driver. Since you can only have one driver installed, if you are using the 32-bit driver and Resman, the 16-bit library will not find any devices.
