VXI and VME
Add a VME device programmatically
Hi all,
is there any possibility to add a new VME device programatically.
using NI-MAX its possible using a wizard as shown. :smileyhappy:
thanks & regards
RENN
Kudos always welcome for helpful posts 🙂
(7,996 Views)
Hi RENN,
did you try to use the API:
How Do I Install the NI-VXI API VIs for LabVIEW? - National Instruments
http://digital.ni.com/public.nsf/allkb/FE222F8BC14EEAA88625705F006CEBD7
(7,968 Views)
Hi Gregor,
thanks for your reply.
it seems i cannot install the NI-VXI 3.6 version on Win7 64 bit OS.
Best Regards,
RENN
(7,965 Views)
Hi RENN,
well, apparently the VXI 3.6 is not supported on Windows 7 anymore. But you can install the latest Version, VXI 3.9 and use the VISA API.
"All VXI programming using NI-VXI 3.7 or later should utilize the NI-VISA API."
(7,961 Views)
Hi Gregor,
i have NI-VXI 3.9 installed on my PC. And i could also see the VXI/VME settings using the VISA instrument property node.
can i create a new VME device using the VISA functions?
i have created a testVI to check the VXI/VME settings offered.  still haven't checked which properties should ne checked to create a VME device.
also had a look at the System Configuration functions, but with no luck. Smiley Sad
Best Regards
RENN
(7,938 Views)
Hi Renn,
what is the output of your VI?
Have no VXI Device for real testing.
best wishes
Dennis
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(7,909 Views)
