02-03-2015 02:06 AM
Hi all,
is there any possibility to add a new VME device programatically.
using NI-MAX its possible using a wizard as shown.
thanks & regards
RENN
02-04-2015 05:34 AM
Hi RENN,
did you try to use the API:
How Do I Install the NI-VXI API VIs for LabVIEW? - National Instruments
http://digital.ni.com/public.nsf/allkb/FE222F8BC14EEAA88625705F006CEBD7
02-04-2015 07:51 AM
Hi Gregor,
thanks for your reply.
it seems i cannot install the NI-VXI 3.6 version on Win7 64 bit OS.
Best Regards,
RENN
02-04-2015 07:56 AM
Hi RENN,
well, apparently the VXI 3.6 is not supported on Windows 7 anymore. But you can install the latest Version, VXI 3.9 and use the VISA API.
"All VXI programming using NI-VXI 3.7 or later should utilize the NI-VISA API."
02-06-2015 02:11 AM
Hi Gregor,
i have NI-VXI 3.9 installed on my PC. And i could also see the VXI/VME settings using the VISA instrument property node.
can i create a new VME device using the VISA functions?
i have created a testVI to check the VXI/VME settings offered. still haven't checked which properties should ne checked to create a VME device.
also had a look at the System Configuration functions, but with no luck.
Best Regards
RENN
02-09-2015 07:33 AM
Hi Renn,
what is the output of your VI?
Have no VXI Device for real testing.
best wishes
Dennis
