VI Analyzer Enthusiasts Documents
Test - Minimum Window Width
by Example Gatekeeper ‎04-18-2013 03:10 PM - edited ‎01-30-2017 08:25 AM
This test checks the panel and diagram windows to see if they are wide enough to display the entire toolbar:
Unless the VI is a dialog VI of a certain size, the panel and diagram windows should always be sized large enough to display the entire toolbar.
This test is saved in LabVIEW 2012. Follow the instructions here to install and use this test.
Contributors
