VI Analyzer Enthusiasts Documents
Test - Forked Event Reg Refnum Wire
by Example Gatekeeper ‎08-07-2013 03:38 PM - edited ‎01-27-2017 03:42 AM
This test returns a failure for any event registration refnum wire (or a cluster wire containing event registration refnums) that has more than one sink:
It is generally considered bad practice to wire an event registration refnum wire to multiple event structures.
This test is saved in LabVIEW 2013. Follow the instructions here to install and use this test.
Comments
Member wirebirdlabs
Member
"It is generally considered bad practice to wire an event registration refnum wire to multiple event structures"
Minor correction: it is unequivocably a terrible idea to bind this registration simultaneously to multiple Event Handler Structure.
Though, it's possible to unbind from one Handler and rebind with another, so long as no time overlaps where both handlers are bound to the same registration.
To see this in action, there are a few demonstrations of these two principles at: https://github.com/wirebirdlabs/LabVIEW-User-Events-Tips-Tricks-and-Sundry
In that repo, 04 - Demonstration - Effect of Branching Event Registration.vi and 03 - Demonstration - Dynamically Rebind Event Handlers.vi demonstrate these two principles.
Thanks for the test, Darren! Static code analysis FTW
Member Ben_Phillips
Member
Jack, this is a _fantAstic_ demo.
I happened to just stumble upon it from the most unlikely place...
Member wirebirdlabs
Member
Thanks!
Contributors
