This test functions identically to the Panel Size and Position test that is part of the VI Analyzer Toolkit, but analyzes the block diagram window instead of the front panel window:
Note that, like the Panel Size and Position test, this test analyzes the VI diagram size and position relative to the primary monitor in a multi-monitor system.
This test is saved in LabVIEW 2012. Follow the instructions here to install and use this test.
