VI Analyzer Enthusiasts Documents
Key Navigation.llb
by Member D* ‎05-12-2014 02:54 PM - edited ‎01-30-2017 09:12 AM
This test returns a failure if a Front Panel Boolean has Key Toggle. This is a problem for System Buttons (<LV2013) by default, and when you reuse code and forget that a button has a key linked to it.
This test is saved in LabVIEW 2010. Follow the instructions here to install and use this test.
Contributors
