Unit Testing Group
Unit testing of point by point VI's
We are making a lot of VI's that are reentrant and point by point to our simulation models. The challenge is to make a unit test with NI's UT framework without using a wrapper VI.
Do any one have any experience with that?
An example on a point by point VI could be as follow: https://decibel.ni.com/content/docs/DOC-1195
/christian
(4,951 Views)
Test Vectors are the answer. You can use these to test VIs like this, I had to do this with some FPGA VIs.
The only problem is with reset behaviour, although test vectors repeatedly call your VI each call is a new call so if you use this as an internal reset it may cause some problems.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
(4,392 Views)
Thanks I will try that
Luckily I don't have a internal reset but only a reset input, so that is not a problem
(4,392 Views)
