USRP Software Radio
usrp 2901 with gnuradio
Hi, there is something I am not sure. Could you help me?
If I run the execution of UHD, like rx_samples_to_file.exe in the path "C:\Program Files (x86)\UHD\lib\uhd\examples". It says that
UHD Error:
         Device discovery error: input stream error
--Detected Device:B210
--Operating over USB 2.
--Initialize CODEC contrl...
Is it normal with input stream error?
Message 11 of 13
(2,251 Views)
Hi leisurely,
I am not able to shed much light on this, but support@ettus.com will be able to provide you additional insight.  I also recommend creating new forums for new questions.  You will likely get more people to respond on a newer one.  Good luck with your project!
John
John R.
Message 12 of 13
(2,229 Views)
Hi John,
Thanks for your kindly suggestions. I will have a try to find out if it matters with this error.
Leisurely
Message 13 of 13
(2,219 Views)
