10-30-2014 04:21 AM
10-30-2014 08:42 AM
radioninja,
1. Can you confirm that the daemon niusrpriorpc processor is running?
2. What version of NI-RIO do you have installed? (If you didn't install this manually/separately from the USRP RIO, then that's good enough.)
3. Are you able to modprobe niusrpriok on its own? The Ettus webpage you linked says "Currently, the latest supported kernel version is 3.14.x." I wonder if the 3.17 kernel has any breaking API changes from 3.14.
Thanks!
10-30-2014 09:25 AM
Brooksprumo,
>>ps -au | grep niusrpriorpc
root 1082 0.0 0.0 27848 4832 pts/2 S 15:13 0:00 /usr/local/natinst/niusrp/bin/niusrpriorpc
niusrpriodistributioni-1.0.1f0. I installed it manually from the .gz from ettus site. Is this version good enough for NI USRP-2952R? I couldn't find any linux driver in NI website also.
Yes, modprobe works. I am not sure about any API changes. The module gets loaded without complaining.
10-30-2014 10:49 AM
Ok, cool. This is all good to hear. The version of the USRP RIO software you have (version 1.0.1f0) was built for UHD verion 3.7, so I'm gonna confirm that UHD version 3.8 should still work with USRP RIO verion 1.0.1f0. In the meantime, can you run `lsmod | grep -i n` and let me know what it says?
10-30-2014 11:00 AM
>>lsmod | grep -i n
niusrpriok 386125 0
NiRioSrv 734204 0
nistreamk 131846 2 niusrpriok,NiRioSrv
nibds 51513 2 niusrpriok,NiRioSrv
nikal 71006 4 niusrpriok,nibds,NiRioSrv,nistreamk
10-30-2014 11:18 AM
Well, everything looks good from your lsmod output. I also confirmed that UHD 3.8 is supposed to work with USRP RIO 1.0.1f0, so unfortunately I'm out of ideas for what to try next... I'm trying to get in touch with the Ettus people directly to see if they have any suggestions or if they've had success with the 3.17 kernel. I guess now that I think about it, if you can get an older kernel, I'd try that out.
10-30-2014 01:24 PM
Thanks brooksprumo. "usrp-users" mailing list is moderated I think. I am not able to post there for some reason. Anyways thanks for the ideas. I will get some SFP+ adapters and will switch Ethernet mode.
