i dont know how to get false alarm graph in labview. i am actually doing it for fading channels too. so i am sending packets using transmitter USRP and receiving it using reaceiver USRP. so i am just checking whether i am getting all the packets correctly or not.. can u help me with the false alarm vs SNR graph?
can you also give me your email id..so i can contact you. thank you so much for your help.
you have to calculate the average power. I had the same problem. The solution is to take 100 (more/less you need) readings from left and right of center frequency, add them and calculate the average.
Hello Sir I am facing problem 1.To record data in xls file at position 1 and 2 in the receiver vi . 2. and when I increase the acquisition time it give memory error can you please tell me how to solve the above two problem .. I want to record GSM data in range of 935MHz-960MHz for analysis. 3. What should be the Ideal sampling of IQ for recording Data. please help with the solution of above problem....
