USRP Software Radio
receive GSM signals using USRP 2920
hello muhammad,
            i dont know how to get false alarm graph in labview. i am actually doing it for fading channels too. so i am sending packets using transmitter USRP and receiving it using reaceiver USRP. so i am just checking whether i am getting all the packets correctly or not.. can u help me with the false alarm vs SNR graph?
           can you also give me your email id..so i can contact you. thank you so much for your help.
Message 21 of 25
(3,784 Views)
Hi mohammed!
Do you still have that application for detection of gsm signals?
kind regards
Message 22 of 25
(2,368 Views)
hello sir can you mail me the labview vi to check these signals on which you are working..( bablukumar.singh@gmail.com) or post it here...
because I am also working in gsm but unable to convert it in values...
Message 23 of 25
(1,158 Views)
you have to calculate the average power. I had the same problem. The solution is to take 100 (more/less you need) readings from left and right of center frequency, add them and calculate the average.
Message 24 of 25
(1,154 Views)
RECEIVER VIRECEIVER VI
RECEIVER PARAMETERRECEIVER PARAMETER
Hello Sir I am facing problem
1.To record data in xls file at position 1 and 2 in the receiver vi .
2. and when I increase the acquisition time it give memory error
can you please tell me how to solve the above two problem .. I want to record GSM data in range of 935MHz-960MHz
for analysis.
3. What should be the Ideal sampling of IQ for recording Data. please help with the solution of above problem....
Message 25 of 25
(909 Views)
