NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
paulosteven
Accepted Solution
how can I transmit a video using the USRP?
[ Edited ]
Hello everybody
I'm new using the usrp and I would like to transmit a video from one usrp to another can someone give me an ideia or tell me if it is possible to do this.
Paulo Steven
Member
Sarah_Y
Re: how can I transmit a video using the USRP?
Hi Paulo,
Do you know which type of modulation scheme/standard you will be using to send your video?  If you are doing analog video will need about 6 MHz of bandwidth which the USRP can provide.  Most TV signals are broadcast around 400 MHz, which is also in the range of the NI-2920.
NI does not offer any toolkits that are designed for this application.  You would need to develop the algorithms for the modulation yourself.  But as far as the hardware is concerned, the USRP should be capable of outputting this type of signal.
Sarah Y
Test Engineer
Ettus Research
Member
paulosteven
[ Edited ]
Hi Sarah Y
thank you for answer my question, I want develop OFDM modulation scheme with labview and i will try to do this if you have some ideia on how can I start please share with me.
Paulo Steven
university student
Member
Sarah_Y
Hi Paulo,
Here is an example that uses the Modulation Toolkit to do OFDM in LabVIEW.  I know that there is a problem with one of the subVIs for this example, but it should be a good starting point for you.
RF Simulation Demo: OFDM
http://zone.ni.com/devzone/cda/epd/p/id/5152
One of the subVIs will show up as broken (Mod_OFDM_bits_Generation_per_Frame.vi).  The problem is that this example was created using an older version of Modulation Toolkit.  In the older version the MT Generate Bits function was not a polymorphic VI like it is in the newer one.  To fix it, all you have to do is place down the MT Generate Bits (poly).vi from the Modulation Toolkit palette and wire it up.  The inputs are not exactly the same, but all of the necessary information should be there.  This is also just a way to simulate OFDM.  You will then also have to make some changes to add the USRP hardware into the code.  The USRP and Modulation Toolkit will function together so once you have LabVIEW generating your OFDM signal, sending it to the USRP should be simple.
Hope that helps and let me know if you have any more questions.
Sarah Y
Test Engineer
Ettus Research
Member
paulosteven
Hi Sara,
Thank you for your attention I will try to do that.
Paulo Steven
University student
Member
paulosteven
Hi Sara,
I followed your instructions and I fixed the problem on that sub VI. the simulation now is working. for now I will try to put it together with the USRP blocks so that I can get my target.
Thank you very much
Paulo Steven
University student
Member
Sarah_Y
Hi Paulo,
I'm glad you got it up and running.  If you get it working with the USRP, would you mind posting your code?  I would like to add it to the community examples and I know there are others out there who would love to see this application.
Sarah Y
Test Engineer
Ettus Research
Member
paulosteven
Hi Sara
When I reach the target I'm going to share it with you
Thank you
Paulo Steven
Member
xibidon
Hi, I'm a Polytechnic student in Singapore. Any idea how to make a transceiver using the USRP with the GNU Radio Companion (GRC)? I need it for my final year proj!! :smileysad:
Member
Anthony_F
Hello xibidon,
To use the USRP with GNU radio and the GNU Radio companion, you will need to reflash the FPGA and firmware with the Ettus provided files.  The NI firmware and FPGA image are only supported by LabVIEW (officially) and the NI-USRP driver.
If you are using the USRP with the UHD, please look at this post: http://forums.ni.com/t5/USRP-Software-Radio/TV-reception-on-USRP/m-p/1980701/highlight/true#M219
Anthony F.
Product Marketing Engineer
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
