01-28-2015 09:37 AM
Hey,
My USRP's are attached to several machines running LV, some LV's are 2013, some are 2014. The problem is that the VI' that I wrote on LV2014 version do not work on LV2013. I did not use anything fancy, just basic blocks.
Can someone please suggest how I can solve this problem?
Filip
01-29-2015 02:37 AM
01-31-2015 04:29 AM
Thanks a lot for the suggestion! I assumed that there is some kind of workaround for this seemingly trivial problem.
\Filip
02-02-2015 04:59 AM
Hi Filip,
This is due to the fact that the LabVIEW compiler is not backwards compadible meaning that VIs need to be recomiled to work with older versions.
02-02-2015 02:38 PM
You should be able to save for a previous version of LV by going to File >> Save for Previous Version...
You will get errors that it is unable to save the NI-USRP VIs in a previous version. That is okay (they have flags that prevent this). Just click Ignore for that error. When you open the VIs you saved in LV 2013, they will find the NI-USRP LV 2013 VIs (as long as you have NI-USRP LabVIEW 2013 support installed).
