USRP Software Radio
calculating SNR of received signal from USRP
Hi, i am using USRP as tranmitter and receiver. i want to calculate SNR of received signal in labview.
Vi of receiver is attached below
(4,324 Views)
The Sound and Vibration Measurement Suite has a VI to do this, but you would have to buy the suite. If you want to adapt a known formula for SNR in to LabVIEW, you'll have to just dive in and use the Mathematics functions to do it.
I found this snippet of code for a peak SNR.
Cheers
(3,952 Views)
Sir,
we are using USRP for real time communication. this is for only simmulink.
(3,827 Views)
