07-06-2014 02:27 AM
Hi! I'm college student from Michigan.
I am doing project with USRP2. My computer has Win7, 32bit, 1Gbps ethernet. Whenever I connect USrp2 with lan cable, first computer recognizes something is connecter. But it always fails to realize that it is Usrp2. So it keeps saying 'Unidentified device'. And NI Usrp, or Usrp Hardware drive can not find the device.
Is it the matter of computer, or the device. We checked that it turns on correctly. Please help me. I have to do this project ASAP,
08-06-2014 09:43 AM
which platform are you using for programming (MATLAB/ LabVIEW)?
I suggest you check the driver is installed?
I you are using MATLAB look up on mathworks website wether your matlab version is compatible with the usrp2. Particularly if you still use earlier version of matlab you migth need to install the support package available here
Best regards
