USRP Software Radio
USRP error
Hi, everyone
     I just installed the latest USRP Driver 1.2 and updated the image and firmware, however, after running for a while, following errow shows up
niUSRP Configure Signal.vi<ERR>A runtime or configuration error occurred.
Code: 1440
Details: RuntimeError: fifo ctrl timed out looking for acks
How can I handle this problem ?
Is there any  possibility that the hardware would be damaged  with updating the image and firmware ?
(7,154 Views)
i just updated my NI USRP-2920 to the latest version (NI-USRP 14.0) and I got the same error message when I wanted to run a program.
I am using LabView 2013 and I tried the Loopback test with the files "niUSRP EX Tx Continuous Async.vi" and "niUSRP EX Rx Continuous Async.vi" (from C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\instr\niUSRP) and got the following error:
Error -1074118627 occurred at niUSRP Open Tx Session.vi
Possible reason(s):
Code: 1440
I also tried other programs (utilizing the NI USRP-2920) but still got the same error.
Do you have any idea how to solve that problem?
Thanks in advance!
Florian
(6,761 Views)
Hi everyone:
I'm using labview 2014 on NI-USRP 2932,
i have several NI-USRP.
My codes works on some devices. however, on others,  i got error message, :
niUSRP Open Rx Session.vi<ERR>A runtime or configuration error occurred.
Code: 1440
i'm sure that the firmware of my devices are correct.
any solution? thanks.
(5,866 Views)
i had the same problem.
Try to disable all firewalls you have installed. And restart LabView (run as administrator).
This was the solution in my case.
Good luck,
Florian
(5,837 Views)
thanks a lot.
problem solved.
(5,828 Views)
