07-02-2014 07:52 AM
Hi, everyone
I just installed the latest USRP Driver 1.2 and updated the image and firmware, however, after running for a while, following errow shows up
niUSRP Configure Signal.vi<ERR>A runtime or configuration error occurred.
Code: 1440
Details: RuntimeError: fifo ctrl timed out looking for acks
How can I handle this problem ?
Is there any possibility that the hardware would be damaged with updating the image and firmware ?
10-14-2014 12:39 PM
i just updated my NI USRP-2920 to the latest version (NI-USRP 14.0) and I got the same error message when I wanted to run a program.
I am using LabView 2013 and I tried the Loopback test with the files "niUSRP EX Tx Continuous Async.vi" and "niUSRP EX Rx Continuous Async.vi" (from C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\instr\niUSRP) and got the following error:
Error -1074118627 occurred at niUSRP Open Tx Session.vi
Possible reason(s):
Code: 1440
I also tried other programs (utilizing the NI USRP-2920) but still got the same error.
Do you have any idea how to solve that problem?
Thanks in advance!
Florian
07-23-2015 10:19 PM
Hi everyone:
I'm using labview 2014 on NI-USRP 2932,
i have several NI-USRP.
My codes works on some devices. however, on others, i got error message, :
niUSRP Open Rx Session.vi<ERR>A runtime or configuration error occurred.
Code: 1440
i'm sure that the firmware of my devices are correct.
any solution? thanks.
07-24-2015 02:56 AM
i had the same problem.
Try to disable all firewalls you have installed. And restart LabView (run as administrator).
This was the solution in my case.
Good luck,
Florian
07-24-2015 03:46 AM
thanks a lot.
problem solved.
