02-10-2014 09:41 AM
I would like to use the USRP as a Software Defined Radio where I can sample a wide spectrum (like 20MHz) and then chose to demodulate a small part of the received spectrum. An example is to sample the whole FM radio band from 88MHz to 108MHz and then from these data FM demodulate 200kHz from a station on 103.9MHz or any other selected signal.
With GNU radio I believe this can be performed by a function called Frequency Xlating FIR Filter which can transform the zero frequency of the IQ data, add a FIR filter and then decimate the data. With LabView I have tried several filters, decimations and transformations but I never end up getting a good output.
Can anyone guide me in the right way on how I can do this?
With regards,
-Sigurd A.
03-11-2014 04:32 PM
I am not sure, but maybe MT Downconvert Passband.vi might help you?
04-25-2014 07:52 AM
Hi,I am also very interested in it, could you provide us with some methods? Thank you!
09-17-2014 01:09 PM
04-20-2015 09:18 AM
Hello, I working in something similar. I have a IQ signal with 2.8 MHz of BW and I need filter a channel of 200kHz of BW, but when I applied a LPF, it not working well and I see in the spectrum frecuency components in the range 0-200kHz and 2.6-2.8Mhz, I need resolve this problem.
