02-26-2015 05:42 PM
Does anybody know how fast the USRPs can execute tasks like tune to a different frequency or read/write to GPIO pins when controlled by LabVIEW? Thanks.
02-27-2015 04:18 PM
Hi mike1234567890,
What USRP model are you using or looking to use?
02-27-2015 04:22 PM
We have N210s with WBX daughterboards. LabVIEW works fine accessing the pins on the WBX granddaughterboard but I'd like to switch outputs to them as quickly as possible.
03-02-2015 10:09 AM
Hi mike1234567890,
The USRP N210 with the WBX board does not look like a combination I am familiar with. I would recommend emailing Ettus support (the people who make the USRP/board combo) at support@ettus.com. They would be able to give you more detailed information and specifications like that.
03-02-2015 11:34 AM
I bet the Ettus USRP N210 is essentially the same hardware as the NI-USRP 2920 or 2930. They have the same specs from what I can tell. The NI-USRP blocks all work with my N210. So do you know how fast the NI-USRP 2920 or 2930 can switch GPIO outputs or if not that, then retune the LO to a different frequency?
03-03-2015 05:37 PM
Hi mike1234567890,
I am looking to see if that is something we spec. It is not in the normal documentation, so it will take a little more digging.
