07-15-2014 06:40 PM
Hello I want to generate a GPS signal using the USRP-2920, and then connect it to a GPS evaluation kit to verify if the evaluation board can see the satellites, so I run the example
https://decibel.ni.com/content/docs/DOC-22178
Everything looks OK, it starts with the legend Buffering Waveform, when it reaches 100 I clicked the Play button and the program stopped and send this error code:
-1074118634
and source:
niUSRP Write Tx Data (CDB Cluster).vi<ERR>Cannot find a GPSDC
Could someone help with this?
Carlos.
07-16-2014 04:19 PM
Carlos,
What versions of LabVIEW, GPS Toolkit and NI USRP driver are you using? I noticed the example you referenced states to make sure to use an external OCXO since the TCXO on the 292x series isn't precise enough. What is going into RefIn?
07-16-2014 05:15 PM
Well, for the OCXO I have a Trimble Thuderbolt but I still did not connect it to the RefIn port. Do you believe this could be the problem?
LabView is 2013, GPS toolkit is version 2 and USRP is Version 1.2.
Thanks for your help.
07-17-2014 12:06 PM
I also looked for the error code
0xBFFA4016 (-1074118634)
and I found this:
0xBFFA4016 | NISWITCH_ERROR_CONFLICTING_TRIGGER_ROUTE_EXISTS | Requested trigger route cannot be made because a conflicting trigger route already exists. |
Can you help?
Carlos
07-17-2014 12:36 PM
Carlos,
It very well could be, so need to try it out before marking off the list of things to investigate.
Regarding your last post with the error about Switch Executive, let's keep in mind that the original error message stated
Is what you listed in the last post an additional error message?
07-17-2014 01:00 PM
Oh yeah, it is the same error. I just added some information about the error.
I'll try with the OCXO, and let you know if that solves the issue.
