USRP Software Radio
USRP-2953R with OpenBts
I am looking for information about using NI USRP-2953R with OpenBts.
What I undestood so far is that I will need to switch to UHD driver and flash FPGA image. Is it correct?
Is there proper image for 2953R?
Thank you,
Marcin
(2,927 Views)
Hi Marcin,
A similar question has been addressed before:
http://forums.ni.com/t5/USRP-Software-Radio/Can-NI-USRP-be-worked-on-GNU-Radio/td-p/1902375
If you read Sarah Y's posts they are very helpful and should answer any questions you have.
The UHD driver can be found at the link below:
http://ettus-apps.sourcerepo.com/redmine/ettus/projects/uhd/wiki
The UHD driver contains the required firmware and FPGA images needed by the USRP.
Courtney
(2,887 Views)
