05-14-2015 04:55 PM
Hi all,
I'm having some problems trying to use the UHD examples.
Some of them I can use. However some of them give me a Segmentation Fault
rafael@rafael-Inspiron-7537:/usr/lib/uhd/examples$ ./tx_bursts --secs 5 --ampl 0.5 --freq 50e6
linux; GNU C++ version 4.8.2; Boost_105400; UHD_003.005.005-0-unknown
UHD Warning:
Unable to set the thread priority. Performance may be negatively affected.
Please see the general application notes in the manual for instructions.
EnvironmentError: OSError: error in pthread_setschedparam
Creating the usrp device with: ...
-- Opening a USRP2/N-Series device...
-- Current recv frame size: 1472 bytes
-- Current send frame size: 1472 bytes
UHD Warning:
Segmentation fault (core dumped)
The same problem for examples like:
rx_timed_samples, test_timed_commands, tx_bursts, and others
I'm using:
-Ubuntu 14.04
-USRP n210
05-14-2015 05:18 PM
Hi Rafael,
While you may find some other UHD users in these forums who can help the best bet is probably to send your question to support@ettus.com since they are much more experienced in UHD troubleshooting.
Best Regards,
Peter W.
RF PSE
05-14-2015 05:39 PM
Hi Peter_W
I just did it, thanks for the tip.
