06-19-2017 01:36 PM
I'm using two NI USRP-2901s with the Modulation Toolkit Examples Tx PSK and Rx PSK.
When I first used this, I could transmit QPSK with no filter and receive with no problems. I left it for a while and returned to try again and for some reason the received IQ constellation won't resolve and seems to pulse in bizarre patterns or in a circle. I've tried changing the parameters and have checked that the parameters match but to no avail.
Please help!
06-22-2017 05:03 AM
Do you still get the problem if you turn off the USRP for a bit and on again?. I suspect that an LO Drift might be causing your issue.
Abdullah
