09-19-2014 06:41 PM
I am currently trying to capture and record an 802.11 WLAN signal from an actual WLAN Router I have in my testbed. My NI-USRP model is an 2932 and I have it say 5 feet away from the router.
It's a NETGEAR WLAN Router and I am certain there are no other WiFi signals around since I have scanned all other frequency channels. The only signal that is being transmitted is the one from the Router I have which I have set to Channel 1: 2.412GHz.
I do see the signal from the router but it seems to have some sort of carrier frequency mismatch or I really don't know what it is.
On the other hand, If I transmit something with another NI-USRP (I also have an 2920 unit, and of course I transmit at a lower frequency range say 2.0GHz so that both USRP units can operate in that frequency range), any type of waveform say a tone or anything, because of the proximity of the units, i do get the signal and there is no such mismatch or error. Of course there is some noise, etc, but not like this.
So when I try to receive the signal from the Router to my NI-USRP 2932 unit, I get this type of raw signal when using the niUSRP EX One Shot RX.vi example:
You can see that it's clearly where the WLAN Frame starts because of the difference in power. It is very clean signal as well, but I see those sinusoidal-like lobes all over the signal.
Any ideas?
Erick
09-19-2014 07:03 PM
09-19-2014 10:02 PM
ErikL,
Thanks for the quick reply. A few more questions:
-Frequency Offset even if the Tx Router and the Rx USRP2932 are in line of sight and like 3-4 feet away?
-How come I don't see a frequency offset when I transmit from another Tx USRP2920 some OFDM Symbols? i.e. How come I don't see the same sinusoid shapes on the Rx USRP2932 when I transmit from an Tx USRP2920 at same distance and LOS than when I do with case Tx Router and Rx USRP2932? (When using case TxUSRP2920/RxUSRP2932, both USRP units Tx and Rx are not synchronized, they are in fact in different computers and different LabVIEWs. I am not trying to synchronize, rather just look at the signal at the Rx USRP2932 in some shape similar to the one on the Tx USRP2920)
Regards
Erick
09-20-2014 06:55 AM - edited 09-20-2014 06:57 AM
09-20-2014 04:38 PM
Thank you ErikL,
I do understand the steps such asi signal acquisition, symbol timing, coarse and fine frequency offset correction, channel estimation, channel compensation, phase tracking and other steps involved in an 802.11 OFDM receiver. But this signal doesn't seem to look anywhere close to a short or long training sequence to actually apply these corrections to it. It seems to be a repeating pattern in fact.
Here are the RAW signals I am receiving (I and Q plotted on graph):
From Router (@2.412GHz):
From another USRP (@2GHz):
As you can see, from the USRP, the signal is discernable and we can actually see the initial preamble. It doesn't look like a sinusoid but still it does have a frequency offset.
I have in fact created an OFDM signal in MATLAB and artificially introduced a carrier offset to it and it doesn't look like the received signal from the router.
Any ideas of what might be happening? Is the NI USRP2932 capable of receiving 802.11 OFDM signals by means of SDR or is there another hardware step that can't be done in SDR? Or what is the difference between transmission from an 802.11 Router and an NI-USRP unit?
Regards
Erick
