07-02-2014 09:52 AM
I tested the delay of latest USRP Driver 1.2 (download from http://www.ni.com/download/ni-usrp-1.3/4711/en/ ) and found niUSRP Abort. vi has unaccept delay of 200 ms ... much larger than the same vi in the older USRP Driver 1.2, it is very unaccountable .
What is more , it seems the latest Driver 1.2 has many problems such as LV program crash and cannot be stopped. I hope these problems will be solved. Thanks a lot
07-02-2014 09:54 AM
I use the latest USRP Driver 1.2 with LV 2012
12-28-2015 09:14 PM
I also want to know why there is the delay of 200ms in niUSRP Abort.vi . Is there any possibilty to overcome this delay or reduce it to less than 1ms. I really hope that someone can give the answer to this problem.
12-29-2015 10:15 AM
Try this newest version (15.0) and let us know if the crash persists and if you observe the same delay in Abort.
12-29-2015 08:20 PM
Okay, Thank you for the reply Sir. I will give it a try and let you know if it can solve the problem or not.
01-04-2016 09:08 PM - edited 01-04-2016 09:09 PM
I try to update the driver as you recommended me before but the delay 200ms in the niUSRP Abort.vi still not solved. Is there another options to overcome this problem?
