07-21-2017 11:52 AM
Hi all,
I'm implementing TX and RX switching for half-duplex on N210 with SBX daughterboard. I'm using one single antenna on TX/RX port. Basically everything works well by now. But I notice that I'm also receiving the signals transmitted by itself. And the amplitude of the received transmitting signals will be increased when I attach another antenna to the RX2 port.
So I'm wondering whether the device is receiving on RX2 port when it is transmitting on TX/RX port?
I referred to the TX and RX switching notes as in shown in Figure 5 here: https://www.ettus.com/content/files/kb/application_note_frontends_subdevices_antenna_ports.pdf
I believe when TX/RX is switched to receiving, the marked TX port would be connected to port 3 and the marked RX port connected to port 2 automatically. However, when TX/RX is transmitting, which means the TX port is connected to port 4, is the RX port connected to port 1 or port 2 at this time? Anyone knows about this?
Thank you!
Cat
07-24-2017 06:07 PM
Hello wucc!
This sounds like an interesting application! I'm curious, are you programming your N210 with the SBX daughter board with LabVIEW? The reason I ask is because there are great examples of programming the Rx and Tx in LabVIEW when you download the NI-USRP driver! You can then use the Rx or Tx Async examples to test, in loopback, whether or not the RX2 port is receiving when transmitting from the TX/RX port.
If you are using another language, I would suggest seeking help from the Ettus support team!
I hope this information is helpful!
Best,
Casey L.
07-26-2017 08:56 PM
Hi Casey,
Thank you for the information. However, I'm using GNU Radio...Yeah, I'm going to contact Ettus for help.
Best,
W
