02-25-2014 04:09 AM
Hi
I am a new user of USRP and GNU Radio.I want to transmit and receive signal at the same time on USRP N210 but while doing this I am getting a timeout error
Traceback (most recent call last):
File "/home/ubuntu/Desktop/top_block.py", line 78, in <module>
tb = top_block()
File "/home/ubuntu/Desktop/top_block.py", line 52, in __init__
channels=range(1),
File "/usr/local/lib/python2.7/dist-packages/gnuradio/uhd/__init__.py", line 116, in constructor_interceptor
return old_constructor(*args)
File "/usr/local/lib/python2.7/dist-packages/gnuradio/uhd/uhd_swig.py", line 2479, in usrp_source
return _uhd_swig.usrp_source(*args)
RuntimeError: LookupError: KeyError: No devices found for ----->
Empty Device Address
I have attached my TX and RX code. Is there something that I am doing wrong in the program.
02-26-2014 09:36 AM
Hey Ninah,
For GRC specific questions, you will get better support using the USRP/GNURadio mailing lists. This forum is targetted at providing support for USPR user using LabVIEW and the NI-USRP driver. You can find the mailing lists here: http://gnuradio.org/redmine/projects/gnuradio/wiki/MailingLists
It looks like you did not provide an IP address/device name for the USRP that you are trying to communicate with based on the error message below. You can find the IP address by running uhd_find_devices. Make sure your IP address is set to static, or else you will not be able to find your device.
