04-18-2015 03:59 AM - edited 04-18-2015 04:01 AM
Hey everyone,
is there any way to switch the transceiver from the same USRP RF-port from Rx to Tx (and vice-versa) during the code execution (even if this switching is controlled by the host)?
I don't know of any example project that does that.
Joao
04-20-2015 10:06 PM
State Machines inside a case structure or timed start can be used depending one likes to control via panel or auto reset.
11-11-2015 11:16 AM
Dear Wired_
Can you give me the sequence block of using 1 USRP for Rx and Tx ?
I'm done with Rx side..from open session until close session...
But I still find difficulties to build the Tx side..
My goal is get signal data using Rx side, process it..and finally, transmit it on Tx side..with the same USRP..
Regards..
11-11-2015 11:19 AM
Hi!
You can see this example. It's same as you want to implement.
