USRP Software Radio
Switch transceiver from RX to TX during code execution
Hey everyone,
is there any way to switch the transceiver from the same USRP RF-port from Rx to Tx (and vice-versa) during the code execution (even if this switching is controlled by the host)?
I don't know of any example project that does that.
Joao
(4,402 Views)
State Machines inside a case structure or timed start can be used depending one likes to control via panel or auto reset.
(4,353 Views)
Dear Wired_
Can you give me the sequence block of using 1 USRP for Rx and Tx ?
I'm done with Rx side..from open session until close session...
But I still find difficulties to build the Tx side..
My goal is get signal data using Rx side, process it..and finally, transmit it on Tx side..with the same USRP..
Regards..
(3,855 Views)
Hi!
You can see this example. It's same as you want to implement.
https://decibel.ni.com/content/docs/DOC-40661
(3,853 Views)
