02-04-2015 08:51 PM
Details: LookupError: Path not found in tree: /mboards/0/dboards/A/rx_frontends/0/sensors/lo_locked.
When I try to work my design, I take this error. (Code: 1074118627)
02-05-2015 09:35 AM
Hi ITUbahadir,
What version of the NI-USRP driver are you using?
What daughterboard do you have installed in your USRP?
This error typically indicates that the driver does not properly recognize the daughterboard that is installed. Providing answers to the 2 questions above can help us troubleshoot your issue and help you get the device running properly.
02-06-2015 05:08 AM
Hi Sarah_Y,
I am using USRPN210 and daughterboard's name is SBX. Also, I am using NI-USRP version 1.2 as software.
02-06-2015 09:40 AM
Hi ITUbahadir,
This is a known issue with select SBX boards. National Instruments has found and resolved an issue that results in the following error message:
Error -1074118627 occurred at niUSRP Initiate.vi Possible reason(s): A runtime or configuration error occurred. Code: 2410 Details: LookupError: Path not found in tree: /mboards/0/dboards/A/rx_frontends/0/sensors/lo_loc
Please contact National Instruments support line: 1-866-ASK-MyNI, and an Applications Engineer will help you resolve this issue.
02-10-2015 01:43 AM
06-24-2017 09:22 PM
05-04-2018 06:57 PM
can you provide details of the solution?
05-07-2018 09:57 AM
Do to the nature of the solution, this issue has to be guided through an NI support request. I encourage you to reach out to an Applications Engineer online or by calling 1-866-275-6964.
05-09-2018 02:45 PM
If I don't have a current service membership will I not be able to access technical support on this issue?
10-15-2019 11:48 AM
please let me know your application engineer email I have a software problem
