05-25-2017 11:17 AM
I have a problem in connecting the USRP to MATLAB. When I use "NI-USRP Configuration Utility" I can see that USRP N210 is connected correctly and the IP address is: 192.168.10.2 but when I command "findsdru" in MTLAB, I get the following:
However I'm sure it's connected. Can anyone help me on this matter?
--Kash
05-30-2017 10:54 AM
Hello khdl!
I would recommend you speak with Ettus Support as you are using an Ettus branded USRP (N210) without NI Software.
Stephen Chan
05-30-2017 11:07 AM
Stephen,
I will, thanks.
--Khdl
