NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Walrus1125
Accepted Solution
Problem of Wideband Spectrum Analysis Example
Hi everyone.
I downloaded the Wideband Spectrum Analysis example and tried it, but it shows no spectrum.
http://www.ni.com/white-paper/13882/en
Configuration:
Anritsu Vector Signal Generator MG3700A==> NI USRP2920 (connected to Windows7 PC)
Freq. 10--50MHz
Power 0dBm
Is there any suggestion?
Member
ErikL
Re: Problem of Wideband Spectrum Analysis Example
The example was designed for use with NI USRP models covering 50 MHz to 2.2 GHZ. Perhaps the software is cohersing the requested center frequency to 50hz for each scan (meaning its not sweeping) rather than returning an error.
Member
Walrus1125
Hi.
I have read your suggestion and I did experiment with the different parameters.  But the trouble has not been solved.  The snapshot is attached, and the error out message is as follows.
Error Description
Error Status Code -1074118639  HeX Code: 0xBFFA4011
Source:Property Node (arg 5)/subsetupRxHWParameters.vi->subSetParameters(HL).vi->Simplified WB Spectrum Sense (Averaged).vi <ERR> The specified attribute ID is not recognized.
Description Error Code-1074118639 occurs at Property node (arg 5)/subsetupRxHWParameters.vi->subSetParameters(HL).vi->Simplified WB Spectrum Sense (Averaged).vi
Reason:
Active Participant
Sarah_Y
Hi Walrus 1125,
What version of the driver are you using?  I'm guessing that you are using version 1.0.  I looked in the subset RxHWParameters.vi block diagram property nodes since that is where the error message indicates the error is coming from.  There is a call to the Active Channel property.  This property is new to the NI-USRP 1.1 driver.  Updating the driver should clear this error.
You can find the 1.1 driver here.
After you update the driver, you will also need to update the firmware and FPGA image.  Here is a KB that explains how to do this.
Let me know if this doesn't fix the problem, I'd be happy to help.
Sarah Y
Test Engineer
Ettus Research
Member
Walrus1125
Hi Sarah,
I was using NI-USRP 1.0 driver.  So, I updated it to version 1.1, and also updated the firmware and FPGA image.
Your advice solved my problems.
Thanks a lot.
Walrus1125
Member
sshearman
All of the new examples (e.g. http://bit.ly/usrpMIMOExample) posted on the example community require the NI USRP 1.1 driver. Unfortunately, some of the new examples were posted before the driver was released publicly. As Sarah mentioned above, the 1.1 driver is available now, so there shouldn't be too many more concerns. Sorry about any confusion.
--Sam
Sam Shearman
Senior Product Manager | Communications & Signal Processing Software | National Instruments
Member
sshearman
I noticed that the link I gave in my previous response no longer works and points to a dead cartoon fish. You can click it if you'd like to see the fish, or you can go to https://decibel.ni.com/content/groups/ni-usrp-example-labview-vis to actually get to some examples.
--Sam
Sam Shearman
Member
sshearman
--Sam
Sam Shearman
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
