USRP Software Radio
NI USRP 2940 R safe-mode button
You are a master!! thanks a lot!!
Best Regards.
Francesco.
Message 11 of 13
(1,392 Views)
Hope this is the right place to ask this
I attempted an ip address change using the NI USRP utility tool and when changed the n210 fpga stopped being recognised by the computer. I am able to boot it in safe mode and the computer can contact the device (ping's okay, and uhd_find_devices is able to locate the fpga). but when I attempt to update the firmware and image it appears to load correctly but on cycling the power the devices disappears.
I have tried all the commands suggested in the ettus manual apart from debricking.
I have two n210's and attempted to change defualt ip of one to 192.168.10.1
Computer interface set to 192.168.10.3
Subnet mask 255.255.255.0
Do you have any suggestions?
many thanks
Message 12 of 13
(870 Views)
Dear Francesco
I met the same problem as u, the LED lights are off when the USRP2942 are turned on and the host cannot ping it through Ethernet. How did you resolve it? Hope to receive your reply asap. Thanks and Best Regards.
Tim
Message 13 of 13
(283 Views)
