06-19-2017 06:47 AM
Please tell me the method to check the compatibility of 782761-01 SBX USRP Daughterboard (400 MHz - 4.4 GHz) with USRP NI 2921.
06-23-2017 10:16 AM
Can you please elaborate?
Do you wish to use the SBX daughterboard on the USRP NI 2921 motherboard?
If so, I think you need to email support@ettus.com.
06-26-2017 12:51 PM
Actually, I just want to confirm if sbx daughterboard can be replaced with NI USRP-2921 default daughterboard, as the default daughter board does not support the GSM frequency range.
06-26-2017 06:11 PM
Yes, that should work if you're using an SBX-40 daughterboard. It'll void your warranty to open up the enclosure to replace the boards, however.
