02-21-2014 02:52 PM
Can anyone tell me what is the major difference or advantages between N210 and niUSRP 2932? Do they have different throughput when I use them as transmitter?
02-24-2014 02:25 PM
Hello zhe310,
If you look from a hardware standpoint, there are many similarities. The NI USRP-2932 contains a mother board, enclosure, RF daughter board and GPS disciplined clock. The N210 is only a mother board and an enclosure.
There are also are few user experiences between the two choices:
The NI USRP is a completely assembled and tested hardware and software package which includes CE certification. The NI USRP is completely LabVIEW compatible out of the box and enables you to access support from applications engineers (like me).
The Ettus USRP allows different configuration options and is typically used with open source software such as GNURadio and programmed in various languages. The Ettus USRP and GNURadio software are supported through email mailing lists.
01-12-2017 12:27 PM
hi.I am using NI USRP 2932 device and I am trying to connect my host computer with device.the software is MATLAB 2013a.So my question is if I am trying to use MATLAB instead of LABVIEW for NI USRP 2932 ,would that lead to incompatibility issues? because when I entered command of " findsdru" in MATLAB,it said "noncompatible",
I will be very grateful if you could tell me that whether there are incompatibility issues by using MATLAB instead of LABVIEW ?
01-13-2017 10:19 AM
Hi Sam,
I would recommend looking at a few other topics that touch on this question, or creating a new thread instead of posting a reply to an older thread that was resolved in 2014.
https://forums.ni.com/t5/USRP-Software-Radio/USRP-2901-with-MATLAB/td-p/3242814
https://www.mathworks.com/hardware-support/usrp.html
Do note that Ettus branded devices (N2xx, B2xx) are different from National Instruments branded devices (29xx), and will interact with different development environments differently.
