I am playing around with the modulation toolkit currently and have two questions:
In the attached example I ASK modulate the bit sequence "1010" and graph the output of the "MT Modulate ASK" block. With M=2, Symbol Rate = 1khz and Samples per Symbol = 16 and Pulse shape filter disabled I get this output:
1. Questions: Why do I only get 8 samples for the first bit?
When I change the Samples per Symblo to 32 (all other parameters unchanged) I get this ouput:
2. Questions: I would have expected to see 32 samples per symbol now. Instead it changed to 16 sampels for a "1" and 48 samples for a "0". What is happening here?
As said I am still learning and trying to understand the fudamenrtals so I would appreciate if anyone could explain that behaviour to me.
Patrick
