12-18-2014 08:53 AM
Just got the news release in my Inbox, and spent a moment looking at the material on the web and have a bunch of questions.
1. What exactly is this? This doesn't look like a "Toolkit", but rather a development environment completely separate from LabView. Is this correct? It looks LabView-ish.
2. What can I do with this that I can't do now?
3. How does this relate to other existing software tools? Modulation Toolkit? Spectral Measurements Toolkit? Signal Processing? USRP driver? etc etc.
I suppose I'm trying to understand whether this is another piece/tool that or an attempt to pull together all the SDR hardware and software as more coherent product.
12-18-2014 04:28 PM
Hi cochenob,
LabVIEW Communications System Design Suite is a new version of LabVIEW designed specifically for the needs of engineers working in the field of communications research and development in mind. You are correct, it is much more than a toolkit. It is a new LabVIEW environment.
There are a lot of new features in LabVIEW Communications designed to provide a single tool chain to go from algorithm development to prototyping on real hardware. For host based prototyping, updated M script nodes and C nodes are included rather purchased separately, and for FPGA based prototyping, a floating point to fixed point math conversion tool and multirate diagram model of computation are brand new additions that significantly speed up the process of algorithm design and implementation.
You can find a white paper and a video about our float to fix tool here:
http://www.ni.com/white-paper/52508/en/
You can find more about the C and .m built in compiler in this white paper:
http://www.ni.com/white-paper/52505/en/
You can learn more about multirate diagram and our advanced compiler here:
http://www.ni.com/white-paper/52509/en/
LabVIEW Communications includes the Modulation Toolkit functions for faster host prototyping. The NI-USRP driver is also included and installed automatically with LabVIEW Communications. If you are curious about all the new features and what is included, I would highly recommend that you download an evaluation copy and check out our online videos, tutorials, and demos:
http://www.ni.com/labview-communications/
If you are interested specifically in LTE or 802.11 research, we have 2 new application frameworks to provide an out of the box starting point for next generation communications research:
http://www.ni.com/white-paper/52503/en/
Let us know as you have more questions, we are happy to help. We have several upgrade options available that will give you access to the new environment.
