NI Home
Cart Cart | Help
You are here:
Reply
Member
Yikai
How can I get a faster Tx IQ rate, such as 5M or 10M
I would like to transmit my PN code as fast as I can. However, I found the maximum transmitting IQ rate I can reach is 2M. If it is larger, the error will come to be "niUSRP Write Tx Data (CDB).vi<ERR>Underflow: the Tx buffer was emptied before new data was provided.  Consider reducing the IQ rate, increasing the Write rate, or increasing the number of samples per Write."
 I have tried to increase the number of samples per write to be a very high value. However, it doesn't work.
Could anyone tell me how to increase the Tx IQ Rate efficiently?
Active Participant
Sarah_Y
Re: How can I get a faster Tx IQ rate, such as 5M or 10M
Hi Yikai,
Streaming data at IQ rates of 5 or 10 MS/s should be achievable on most systems.  I have a few questions and a few suggestions for you.
Questions
  • What type of computer are you using?
  • What is the processor?
  • What is the Ethernet chipset?  Or are you running your USRP using a PCI/PCIe gigabit Ethernet card?
  • Are you using an example that came with the driver or code that you wrote yourself?
Suggestions that have worked for myself and my coworkers
  • Change the computer's power setting from the default 'balanced' option to 'high performance'
  • Use the built in Ethernet port if possible.  If you are using a PCI/PCIe version, make sure it is a high quality card.  The cheaper ones cause dramatically poorer performance than the slightly more expensive ones
  • Turn off your virus scanner and other memory/processor intense programs
  • Check the "data Streaming Performance Tips" in the NI-USRP Help document.  There is a registry key that can be changed to help improve streaming performance
There are a lot of different factors that can cause poor performance with a USRP.  Please let me know a bit more about your system and the code you are running so I can better help troubleshoot this problem.
Sarah Y
Test Engineer
Ettus Research
Member
Yikai
Hi, Sarah
I use a 64-bit SONY laptop with AMD Athlon(tm) II P340 Dual-Core Processor and 4GB RAM. The Ethernet port is gigabit type. I connect the board to the laptop through Ethernet cables via a gigabit switch. An Tx example in the driver (in the attachment) is used for test.
After I take your suggestions that change the computer's power setting to "high performance", turn off the virus scanner, the rate still can't reach higher.
Yikai
Member
Mjsalv
Hi Yikai,
Just wondering if you ever got this to work?
I'm having the same difficulty. What daughterboard are you using?
Thanks!
Active Participant
Sarah_Y
Hey Mjsalv,
If you have tried everything mentioned above, you should also try changing your registry key.  How to do this is described in detail in this post:
http://forums.ni.com/t5/USRP-Software-Radio/Increasing-write-rate/td-p/2165368
Sarah Y
Test Engineer
Ettus Research
Member
Adnan_Raja
Faster Tx IQ rate: 16M samples/sec
Hi Sarah and others,
I need to send data at 16 Ms/sec in my application. But I am having problem doing so.
Is this possible ? I checked the various threads on this forum and can now write at 4 Msamp/sec, but I am not able to go beyond it.
I am using:
- NI-USRP-2921
- Intel Core2 Quad CPU with 8 GB RAM
- Windows 7
- RealTek RTL8168D/8111D family PCI-E Gigabit Ethernet NIC
- I am using the "NI USRP Write Tx Data (poly)" vi
I changed the registry key to HEX2400, amde sure that the firewall is turned off, and changed the power options to high performance mode.
When I try a Tx sampling rate of 8 Ms/s, the subCallConfigTX.vi return a Tx sampling rate of 7.69 Ms/s and I get the following error.
"niUSRP Write Tx Data (CDB Cluster).vi<ERR>Underflow: the Tx buffer was emptied before new data was provided.  Consider reducing the IQ rate, increasing the Write rate, or increasing the number of samples per Write."
I would appreciate any help.
Adnan
Member ORN
Member
ORN
Re: Faster Tx IQ rate: 16M samples/sec
Hi
If you can manage with 8 bits samples ,this would half the data sendt to the USRP,
try change the network-adapter Transmit buffer size , it may help
i manage receiving at 25 MSPS i 8 bit mode, but i have a dedicated network adapter directly to the USRP,
 it is only stable if you don't do any other network access to another network-adapter.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
