04-25-2012 12:56 PM
Is this the proper forum for Visual C++ questions for accessing the API of niusrp.dll? I hope so...
I'm beginning to write VC++ code to control the Ettus N210. The first call that my application makes into the DLL is to API function niUSRP_OpenTxSession. That call seems to succeed, returning a zero status (no error), and giving me a valid session handle (non-zero). However, when I make the call inside the Visual Studio debugger, I see a rash of "first chance exceptions" that occur while that API call is executing. I know that a first chance exception is generally benign if handled, but I'm concerned that I may have a configuration problem because I wouldn't expect exceptions to be a natural part of the program flow.
Here is a listing of the exceptions I get. This is in a legacy VC++ 6.0 application, calling the niUSRP API functions by indirect means (LoadLibrary and GetProcAddress), not by direct linkage. I'm not sure if that matters.
First-chance exception in ... (KERNEL32.DLL): 0xE06D7363: Microsoft C++ Exception.
First-chance exception in ... (MSWSOCK.DLL): 0xC0000005: Access Violation.
(many more identical exceptions omitted...)
First-chance exception in ... (KERNEL32.DLL): 0xC000008F: Float Inexact Result.
Can these exceptions safely be ignored? Are they indications of a problem?
Ed
Solved! Go to Solution.
04-25-2012 02:55 PM
Hello Ed,
The USRP driver only has support for a limited number of RF daughter boards. Can I ask which daughterboard you have in your N210? Additionally I would like to know if you are using version 1.1 or 1.0 of the USRP driver on your computer.
I do not beleive we have published any text-based examples for programming the USRP. Could you post your function calls to LoadLibrary, GetProcAddress and the call to nuUSRP_OpenTXSession? I have not done this in C, but it is possible that LabVIEW doesn't pass these exceptions through since they are not fatal. I will need to look into this further to give you a better answer
04-25-2012 04:51 PM
The daughter board installed now is an "SBX Board Rev 3".
I also have a "Basic RX" board and "DC-50 MHz Receiver" board, neither of which I've tried yet.
Following is the essence of the code I am using. The call to fpOpenTxSession generates the exceptions visible in the debugger, but returns gracefully.
// based on niUSRP.h, this is the signature of niUSRP_OpenTxSession (and Rx too):
typedef niUSRP_Status (__stdcall *FPOpenSession)(
niUSRP_String deviceNames,
niUSRP_Bool reset,
niUSRP_Session* sessionHandle);
FPOpenSession fpOpenTxSession = NULL;
// load the USRP DLL, and map the OpenTxSession function
const char *libname = "niusrp.dll";
HINSTANCE hLib = LoadLibrary( libname );
FPOpenSession fpOpenTxSession = (FPOpenSession) GetProcAddress( hLib, "niUSRP_OpenTxSession" );
// open a TX session
niUSRP_Session session;
int niStat = fpOpenTxSession( "192.168.10.2", true, &session );
04-25-2012 05:01 PM
Sorry, I forgot to include the version info for the niusrp.dll file.
I hope this is what you need...
From the readme file:
Version 1.0
From right-click properties on niusrp.dll:
File version is 1.0.0.49153.
In the "Other version information" section:
Comments: 2011/09/01 19:29:29, niusrp/win32U/i386/msvc90/release
File Version: 1.0.0f1
04-26-2012 08:26 AM - edited 04-26-2012 08:33 AM
Hello Ed,
Just as a heads up, version 1.0 may not work with those daughterboards as it was only tested with the XCVR2450 and WBX. The NI-USRP version 1.1 adds support for the daughterboards you have (SBX, BasicTX, BasicRX and others).
I believe the first-chance exception is probably nothing to worry about, given the definition of a first-chance exception and the fact that the function calls are returning niUSRP_Status_Success.
Also, you may not have noticed but, there is a .lib file that you can statically link to instead of using the LoadLibrary and GetProcAddress calls. This .lib is located at \Program Files\National Instruments\NI-USRP\lib
I would also double check the header file after you update.
04-26-2012 09:32 AM
Ed,
NI-USRP 1.1 adds support for your daughterboards.
As a C++ customer you are also encouraged to use the UHD (USRP Hardware Driver) which provides a C++ API and supports all of the Ettus daughterboards.
http://code.ettus.com/redmine/ettus/projects/uhd/w
Install instructions: http://code.ettus.com/redmine/ettus/projects/uhd/w
Examples: http://code.ettus.com/redmine/ettus/projects/uhd/r
API Documentation: http://files.ettus.com/uhd_docs/doxygen/html/names
04-26-2012 04:58 PM
Upgrading to v1.1 of NI-USRP got rid of all but two of the exceptions. I can live with the exceptions that remain, knowing that they are benign.
I saw a couple of differences in the niusrp.h file after the update. The ability to get a list of all devices that can be reached on the network is nice, so now I can provide a default device (i.e., first in the list), which having to know the IP address in advance.
I was aware of the ability to use niusrp.lib to statically bind to the DLL, but I chose not to us it so that I can avoid the requirement for that DLL to be present just to start my application.
I also saw the recommendation to use the UHD driver for C++ development, but I have not yet investigated that option. It looks like a bigger learning curve than just getting the niusrp APIs to work directly.
The APIs supported by niusrp.dll seem fairly straight-forward, and my interface requirements are simple. I just want to configure the device for frequency, sample rate, etc., and let it stream to me. I've seen the LabView documentation, but I'm not a LabView guy, so it hasn't been the easiest thing to wade through. I would also benefit from an overview of how to set the device up, i.e., which sequence of operations is required to get Rx data streaming. Can anyone point me to documentation for the "big picture"?
Ed J.
04-26-2012 05:34 PM
Update:
I was able to find the following LabView link that helped me to understand the "big picture" that I had asked about earlier. I'm up and running now. Thanks for the help.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
