Hi I started learn Labview with using USRP-2922. Currently I just set up the system and understanding examples. Whenever I open modified example file, it's IP adress always same as default although I changed and saved as another file. Also Whenever I want to change frequency range by using this path > right click on graph > Scales> Unclick autoscale and entering min and max. values, it seems changed but after closing and opening the file it is not changed. How can I save my changes on my files. In addition, could you give more examples(to learn step by step), datasheets and white papers about USRP? Regards
Dear Rui, Thanks for reply. I changed IP adress but I could not modify graph axis. I want to change frequency range and whenever I started my modified file, I want to see modified frequency range. Could anyone help me about this matter?Thanks.
Which example are you running? I would think the graph would autorange to whatever frequency range you USRP is using. Just changing the range on the graph isn't going to change the actual data being displayed.
