04-26-2017 09:07 AM
Hello there,
hope you can help, i think it's not that difficult but i don't get it.
In my USRP Tx i just want to add a variable delay time to my acquired signal for processing. As you can see in the attached picture of my Tx, i get the time information and will add any delay you enter. For example: I want to delay the acquired signal for 50ms. But if i compare the original signal with the delayed signal there is no difference doesn't matter what i entered in the delay-element. I know there's a express VI for time delay, i only used it to see what i should expect, but it's not a durable solution for me. So it won't work and i don't know why.
Please ask if something is not clear. 🙂 Thank you!
cheers,
Jendrik
04-27-2017 09:16 AM
Hello Jendrik,
i tested you code and it worked fine on my side.
I believe that you just do not see the difference because you did not activate it on your Waveformgraph.
There is a Checkbox on the in the Properties of the Waveformgraph-->Scales which says:
Ignore waveform time stamp on x-axes
if you want to see you you delay in that waverform you have to uncheck that.
Basically you can also convert the express Vi, by right-clicking it and and click on open Frontpanel. Than you can see what happens inside.
Best regards.
L.
05-02-2017 02:30 AM
Hi Leopold,
thanks for your reply.
I tested your solution, but if I uncheck the ignore time stamp I get something you see in the attached picture. later i formatted the x-axis manually and then i get nothing to see. There's also another problem: Normally if you multiply a sine wave with it's delayed replika you will get a new wave with the doubled frequency and an offset. But in my case i get no offset, only a sine wave with it's doubled frequency. Isn't that a proof that this is not only a display problem?
Jendrik
05-02-2017 04:24 AM
I just wanted to edit my recent post, but i think it's not possible so here's an update:
Now i understood what happened with my x-axis. I think Labview is converting the time stamp to a double value or something like that. I see my "delayed" signal but only if the x axis is on autoscale. My signal is between 357656114.25 to 357656114.26, haha.
But with this scale a real comparison is not possible. Do you have an idea what I could do that my signal is also between 0 and 0.01?
05-04-2017 05:20 AM
Hi Jndrk,
here is described where the numbers you see come from. It is the Timestamp used by Labview or in your case from the USRP.
http://www.ni.com/tutorial/7900/en/
You could easily set that timestamp to zero with a constant or you subtract the t0 by itself. Then you have your data starting at zero.
Best
L.
