10-27-2016 06:41 AM - edited 10-27-2016 06:42 AM
Hello Everebody,
I have not much experience about 2943R .I have two 2943R . I want to implement 2X2 MIMO QAM with alamouti coding using 2943Rs. I will use Ch0 and Ch1 of Tx USRPR and wil use Ch0 and Ch1 of Rx USRPR.
I camed across an example for in response to at this link: https://decibel.ni.com/content/docs/DOC-42025 which have been sent for single USRP RIO. That vi is present at the attachment of my message (2x2 QAMAlamouti with BER (modified for single USRP RIO)) . It is running only for single RIO. If I choose RIO0 for Tx, and choose RIO1 for Rx, it didn't run. I connected Ref Out of Tx USRPR to Ref In of Rx USRPR. Also similarly I connected PPS Out of Tx USRPR to PPS In of Rx USRPR with SMA cables. In addition, inside subInitHW.vi block diagram Ref Frequency Source and Ref Time Clock Source of Tx are selected as internal both. Ref Frequency Source of Rx Ref In is selected and Ref Time Clock Source of Rx PPS In is selected. How could I modify attachement vi for two USRPR?
Best Wishes
10-31-2016 10:30 AM
Hi!
I would like to bring your attention to this white paper on 2x2 MIMO using our USRP RIOs.
Could you give us the error you were receiving when you said it "didn't run?" There are many reasons LabVIEW code may not run, and it would be very helpful if you could share the error code you were receiving.
Stephen
02-04-2018 10:31 PM
anyone share with me a VI with Implementing 2x1 MISO system with LabVIEW and NI USRP 2921?? I need problem with the estimation channel in the receptor, i used the alamouti code with 2 antennas trnasmitter and one antenna receiver.
