10-21-2013 09:09 AM
Hi youngmin,
I used your instructions but it doesn´t work.
The error message is:
Why I get this problem?
Thank you.
11-15-2014 07:33 AM
hi stiefvap,
I got the exact same problem like you. The first error occurs in the VI for sendig the data stream (in the transmit/receive VI). There is a timestamp error when I put a probe into the VI.
How did you solve this problem?
I would be very thankful for any help on that issue.
Sincerly,
Paul
12-01-2014 04:46 AM
I'm also having some trouble with this anyone manage to get a working verson?
01-12-2015 08:42 PM
Where do you change the changed channel list option ?
04-08-2015 05:49 AM
So there is still no solution to the problems stated above? Where are these NI guys ? I am also facing similar issues.
04-23-2015 06:54 PM
This is telling you that your input array is empty. That means that there is an error somewhere along the line in your RX. Put your schematic up on your screen. Then look in the upper left hand corner of your screen, next to the pause button there is a light bulb. Press it and the one to the right of it. This will show you the size of your arrays at each wiring point along the scheme. It will also show you where errors occur. Now run the program and watch what happens. You will notice that the arrays change sizes inbetween the VI's representing the attributes of the signal. This should help you find out where your issues are.
Good luck!
-J
