UI Interest Group Discussions
Decoration hidden menus
Full credit to the users on LAVA: https://lavag.org/topic/18469-i-found-some-more-hidden-ini-keys/
A hidden set of menus that may be of use when creating custom controls.
These only become available with the secret popups ini key set to true and when you are in the control customise mode.
The menus change depending on the main control type being customised.
Customise mode:
Added menus when right clicking a decoration of a cluster contol:
ImageRaw text (for search indexing)
Keep Away Move
Left Move
Right Move
Top Move
Bottom Move
Left Grow
Right Grow
Top Grow
Bottom Grow
Left Prop Grow
Right Prop Grow
Top Prop Grow
Bottom Prop Grow
Aspect Grow
Slave to Frame
NoSelectMask
NoGrowMask
NoTrackMask
Credit source
Using LV2018 32 bit
Highly recommended open source screen capture software (useful for bug reports).
https://getsharex.com/
Message 1 of 11
(7,868 Views)
Example usage attached. Resizable control using 9 slice scaling.
No pixelation on resize. LV11 onwards.
Using LV2018 32 bit
Message 2 of 11
(7,037 Views)
There is also a "Non-colorable boolean decal" option that shows up on decals, which lets you color the object underneath the decal.
Message 3 of 11
(7,037 Views)
I cannot believe that NI has not opened the 9-slice button for the masses.  I have wanted this for years.
Message 4 of 11
(7,037 Views)
I can't seem to find that one. I've tried importing an image from the clipboard and file to replace a button element, but no luck.
I see what you mean now after viewing these: https://decibel.ni.com/content/docs/DOC-17431
Using LV2018 32 bit
Message 5 of 11
(7,037 Views)
I know right! The same with loading and displaying images with 8bit alpha channels at runtime. It would oen up so many more possiblilities with that.
I wonder if it's theoretically possible to generate contols similar to the silver set that seem to support vectors with anti-aliasing. Or if those items are hard coded into LabVIEW.
https://lavag.org/topic/9749-labview-vector-format/
Using LV2018 32 bit
Message 6 of 11
(7,037 Views)
What is this ini key?  And can you possibly update the guide to give a walk through on how you created your example 9 slice?
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 7 of 11
(7,037 Views)
I've updated the original post to include a link to the source (I'd originally set all of the keys a long time ago and forgot about their effects).
I will try and produce a guide in the next few days.
Using LV2018 32 bit
Message 8 of 11
(7,037 Views)
For the record, I found also (LV2017)
Slave to Housing (slider)
Disconnect decoration (Silver multicolumn listbox)
rather than peeking yet another and another one, Is there btw a semipublic description of how to put all this tags to good use? There are many which at first I can't guess what they are for, like all the Prop Grows.
Message 9 of 11
(6,200 Views)
Proportional Grow, so if something covers only part of the control, it will grow in proportion.
Message 10 of 11
(6,192 Views)
